Tractor_Jim_CT
I am about to plant about 20 evergreens I purchased from a local nursery. The plants range from 4 to 6 feet each and have a burlap covered root ball.
I was thinking of using a towing strap to wrap around the botton trunk of the tree to lower the tree into the hole. The technique used to lift and lower the new tree can also be used to lift the tree back out of the hole if the hole is not deep
or wide enough.
I have hooks on the FEL or should I life with bH?
or wide enough.
