Question on Deutz engine
/ Question on Deutz engine #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
At work we just picked up an older 6 cyl deutz engine.. perhaps fromt he 70's It's a stationary power unit to run a large trash pump.
One of the cyls is leaking fuel, and the mechanic doesn't want to 'try' to pull the injector unless he knows how / what to expect.. and well.. the engine is older than him.. so he's never worked on one.. etc...
here are the numbers from the data plate:
135 hp 2300 rpm
(printed on tag DIN ) B 6270
0957 / 07
BF6L913
6668169
If anyone could let me know how to pull the injector, I'd appreciate it. Theory is right now that the injector tip may be broke... If you crack the line to the injector.. not much fuel bubbles.. however if you pull the line, there is a decent amount of fuel.. or a sealing disc ( copper washer? ) under the injector is leaking.. According to the mechanic, there is a fuel leak at the cyl. I havn't had my hands on it, so all I know is it is not the return line and bajo fitting, or the pressure line to the injector.. so those are our guesses at this point. Any takers?
Soundguy
/ Question on Deutz engine #2
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
2012 Ford F-150 Crew Cab Pickup Truck (A61568)
2012 Ford F-150...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A63118)
1995 Ford F-250...
New/Unused Landhonor Quick Attach Backhoe (A61166)
New/Unused...
Galvanized Livestock Wire Gate - 4FT x 11.5FT (A56436)
Galvanized...
2025 Hercules 14 Gun Safe (A61569)
2025 Hercules 14...
