question on belts
   / question on belts #1
twoodard04
clyde ny
in market
Needing a new belt on my mower. It's a 1/2" 122". Can a 5/8" 122" be used in its place?
   / question on belts #2
Depends on where the belt goes. My JD lawn mower deck uses both the inside and outside of the deck belt to power the pulley and idlers. The measurement for the ,"v" part of the belt may change also. I do not use factory belts due to the cost. Finding the right belts takes some time. I wish you luck.
   / question on belts #3
The profiles of the belt have to match. Has to be the right duty type.
   / question on belts #4
If the belts have the same angle, the larger belt will ride higher in the pulley groove. Make sure you have enough give in the tension system, or get a longer belt.
   / question on belts
This would be the blade drive for a Swisher 60" trailmower
   / question on belts #6
are the pulleys an A pulley or a B pulley? an A belt usually will work with a B pulley but a B belt will not work well with a A pulley. It will not fit into the pulley and the sides of the belt is what pulls or traction is obtained, and if it will not fit in the pulley, it will pull less than the A belt..
   / question on belts
How would I identify each type?
   / question on belts
The factory replacement is 1/2" but it seems to be riding deep in the pulleys.
Heavy Duty Jumper Cables (A51694)
Heavy Duty Jumper...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
2012 Hyundai Genesis Sedan (A51694)
2012 Hyundai...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2022 Ford F-250 XL...
2015 TROXEL 130BBL KILL TRAILER (A53843)
2015 TROXEL 130BBL...
