Flail Mower Question on Befco H25 Flail mower
   / Question on Befco H25 Flail mower #1
arcteryx
Bronze Member
Texas
JD 3032E w/ Loader
I have an older BEFCO H25 flail. The sprig that connects to the tensioner popped of, which caused the belt to jam. I now need a new belt. Coupe of questions-
1) Does anyone have a user/service manual for this?
2) Does someone know what size belt is needed?
3) Is there a pic that details how to attach the spring back on the tensioner and flail body?
TIA
   / Question on Befco H25 Flail mower #2
Give me a few minutes;
If your tensioner has popped off chances are very good that
the spring needs to be replaced also.
The V belt will be easy to replace, you can take the old belt to a
NAPA or TSC, Menards, Farm and Fleet, etc., and obtain a new one.
I would contact Befco directly for a manual and a spring or your nearest Befco dealer
I am pretty sure thier flail mowers are an italian brand under that Befco paint.
About the spring- you should be able to find the mounting point very easily as the spring
has limited amount odf stretch to do work; there should be an extended bolt head or a hole in
one of the weldments under the belt guard that holds the flat tensioner pulley against the flat
portion of the belt.
You should also check with German-Bliss Equipment about a manual for your H25 Flailmower
Welcome to the Flail Mower Nation.
Much obliged! I will contact BEFCO and see what they can do.
2019 Ford F-350 4x4 Crew Cab Auto Crane EHC-4 4,000lb Crane Service Truck (A50323)
2019 Ford F-350...
2018 CATERPILLAR 326FL EXCAVATOR (A51242)
2018 CATERPILLAR...
John Deere 960 Culitivator (A50514)
John Deere 960...
JOHN DEERE 3020 TRACTOR (A51243)
JOHN DEERE 3020...
2012 Ford F-250 Ext. Cab Omaha Service Truck (A50323)
2012 Ford F-250...
SCAN TO RECEIVE TEXT UPDATES (A51244)
SCAN TO RECEIVE...
