Question on Air Filter for a Ford 3910
   / Question on Air Filter for a Ford 3910 #1
frankmako
Bronze Member
North Georgia
Ford 4610, Ford 3910 and YM1601D
The operator’s manual states, “the inner air filter should only be serviced by the dealer”. So what gives?? For the outer filter I just remove the wing nut and pull it out. The inner filter is held in by one nut. It looks like I can remove the nut and pull it out just like the outer filter. Or is there something special that must be done to remove the inner filter.
   / Question on Air Filter for a Ford 3910 #2
I'll check my manual and my tractor tomorrow Frank. I am not sure what has to be done on it but I will check to see and get back with you in the next couple of days.
Thank You
Frank
   / Question on Air Filter for a Ford 3910 #5
My 7610s has an inner and outter.. you change the inner as soon as it shows signs of being dirty. Since I love my 7610s.. I change the inner and outter at the same time..
soundguy
   / Question on Air Filter for a Ford 3910 #6
i need a air cleaner housng and filters for a 3910 ford 1990 year model
   / Question on Air Filter for a Ford 3910 #7
i need a air cleaner housing filters for a ford 3910 tractor.
   / Question on Air Filter for a Ford 3910 #8
have you tried a CNH dealer?
2000 Dnya RGN T/A Trailer (A49461)
2000 Dnya RGN T/A...
2019 PETERBILT 579 SLEEPER (A51222)
2019 PETERBILT 579...
STIHL TS420 CUTQUICK SAW (A50854)
STIHL TS420...
INDUSTRIAL SAND BLASTER (A50854)
INDUSTRIAL SAND...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
