Question on Adobe fillable forms
   / Question on Adobe fillable forms #1
Sigarms
Super Star Member
Mid north west in the state of N.C
F3080
How do you create a text field that will let the end user type in all the info needed without having the text "cut out" so you can't read it all in the field?
I've noticed that when the field is created directly from the form, the end user can type in all the info you need and the font just keeps getting smaller to keep everything in the field so you can read it.
I've looked at the properties section in the text field (when I've created a text field), but still can't figure it out.
Anyone have a suggestion?
   / Question on Adobe fillable forms #2
so, it would help if you stated what software you are using to create the PDF ...
I use Foxit Phantom and on the "appearance" tab of "text field properties", in the "text" block, the setting for "Font Size" needs to be set to "auto".
The result is both scrolling and shrinkage
Adobe Pro.
The font size was the key. I didn't realize you have to keep scrolling "smaller" to get to auto in the format field.
Sincere thanks. It was driving me UP THE WALL!
2016 JLG 3248RS Electric Scissor Lift (A56857)
2016 JLG 3248RS...
Husqvarna 46in Riding Mower (A56859)
Husqvarna 46in...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A55315)
2025 Mahindra 6075...
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
