Okay...I'll try..in case you can't tell, I'm a little tractor ignorant! There is a little control valve (about the size of a time with a groove in it) next to the hydraulic filter. He told me to make sure the groove was horizontal. It was vertical so I moved it. The 3 point thing in the back worked after that but the front end loader still wasn't moving (well, just barely). Then...there was a hose coming from around the filter going to the front end loader that was connected with a quick connect valve that was not firmly connected. Then I read the manual about the front end loader and it said that the little control dime should be vertical when the front end loader was attached so I moved it back to the vertical position and ta da! all was well. So I'm not sure if it was the loose hose or the valve or a combination of both but it is now working great. (Which is a good thing because my husband is getting a little stressed out from not being able to ride around the pasture on his tractor! ) You men have a thing about these tractors!
I hope this makes some kind of sense!! /forums/images/graemlins/confused.gif
