Question JD 3032R & 3039R 2015
   / Question JD 3032R & 3039R 2015 #1
JKR
Washingtonville NY
JD 3033R
I have a 3033R 2015 on order. In the JD brochure it said nothing about the engine being turbo charge or the 3039R.
But on line I just read that both ate turbo charge.
Do you if this is true.
   / Question JD 3032R & 3039R 2015 #2
3033R
The 1.642-L displacement, naturally aspirated, 3TNV88C Yanmar diesel engine provides 31.8 hp to the 3033R Tractor.
Model
Number of
cylinders
Engine
displacement
Rated rpm
Gross engine hp*
Gross engine ps*
PTO hp*
3033R
3
1.642L
2600
31.8
32.2
23.6
*Engine hp (kW), gross SAE J1995: 32.2 (23.7) at 2600 rpm, PS
Displacement, in3 (L):100.2 (1.642)
3039R
The 1.496-L, turbocharged, 3TNV86CT CR Yanmar diesel engine provides 38.2 hp to the 3039R Tractor.
Model
Number of
cylinders
Engine
displacement
Rated rpm
Gross engine hp*
Gross engine ps*
PTO hp*
3039R
3
1.496L
2600
38.2
38.7
31.3
*Engine hp (kW), gross SAE J1995: 38.7 (28.5) at 2600 rpm, PS
Displacement, in3 (L): 95.7 (1.568)
Thank you.:)
That's what I though after going though a few search but wasn't sure.
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
New Holland 650 (A50123)
New Holland 650...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
