Question for JJ
   / Question for JJ #1
3238dpw
Central NJ
Power Trac 425, C-121 Wheel Horse, 2 Exmark 60 inch zero turn mowers
   / Question for JJ #2
3238dpw said:
JJ,
I came across this thread you started. I was wondering if you could give us more info on this? How wide is it. How far do the jaws open? Is it sized right for your machine or do you think that it would fit the 425 better?
http://www.tractorbynet.com/forums/power-trac/54517-root-rake-grapple-combo.html
Scott
Scott, The frame is just a 2 in hitch assembly for a large car or truck. You could also use 4 in box 1/4 walls. You can build it to any size. What I built, would work quite nicely on the 425. Use as many tines as you like. It will open about 170 degrees. The grapple part is controlled by the aux hyd circuit, but you could add an electric valve, with a switch on top of the joystick for the grapple.
I have many pictures of root rake/grapples.
   / Question for JJ
I was also wondering how wide is your grapple? Do you like it? What improvements would make?
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
FORD 8770 TRACTOR (A51247)
FORD 8770 TRACTOR...
2021 John Deere 310SL Backhoe (A53342)
2021 John Deere...
Case TV380 (A50123)
Case TV380 (A50123)
2017 HITACHI ZAXIS 250LC-6N EXCAVATOR (A51246)
2017 HITACHI ZAXIS...
