ampsucker
Platinum Member
Hey all ! Hope your doing great!
Took delivery of new 20' trailer last week. In going over it now that the weather is better around these parts, I'm wondering about the safety chains that came with it. The trailer is rated for 7,000 lbs with a 2" bulldog coupler. My understanding of the SAE J684 hitch spec is that each safety chain must be independently able to carry the full load of the trailer by itself and that there must be two such chains (double failsafe). From looking around, that would mean we are talking about at least a 5/16" grade 70 transport chain with similarly rated latching hook. I think that size chain is good for around 4,700 lb working load limit, so actually, it would need to be a little better to get up to the 7,000 lb capacity of the trailer.
Am I understanding this correctly? I realize the loads on the chains could be quite a bit more or less than the weight of the trailer should the hitch ball ever fail (lateral jerking, jack catching a ridge in the road surface, etc.) but is this basically what the spec is calling for? They supplied two chains with no markings that appear to be 1/4" links with soft metal latching s-hooks. I'm not buying that is good enough.
For what it's worth, I mounted 9,000 lb d-rings to my towing vehicle's class iv hitch so these chains will be attaching to something substantial. The draw bar on the truck is rated for 10,000 lbs after figuring the 4" drop as is the hitchball.
Thanks....
Thanks....
