Question, blade removal on '94 1440
   / Question, blade removal on '94 1440 #1
Frosty2
Bronze Member
Hammond,IN
94 Cub Cadet 1440
Having trouble removing nut to do blade sharpening. Could it be lefthand threaded? Tried counterclockwise with no luck. Can't find the info in the manual that I have. Thanks, Dave
   / Question, blade removal on '94 1440 #2
They are right handed threads. The manual for your 42" deck says the nuts are torqued to 90-110 ft lbs. If this is the first time you've had to remove the nut you may need an impact wrench to remove them. C-clamp a block of wood inside the deck to stop the blade from turning. When you put them back on you some anti-seize on the threads. I uploaded the deck manual here 42in_deck772-4123b[1].pdf[1].pdf
Thank you for the info and the link. I saved a copy for reference and appreciate your help.
   / Question, blade removal on '94 1440 #4
Sometimes I have to use a wrench on the pulley to counter the force on the blade nut. If you haven't used anti-seize on the threads try spraying some PB blaster it may help.
   / Question, blade removal on '94 1440 #5
i always have to use a wrench on the pulley. ive even had that almost not quite be sufficient. at 100 ft lbs your going to have to really put some arm into it if theyve never been off or if theres locktite on them.
Bobcat 3560 Skidloader Breaker (A50774)
Bobcat 3560...
2013 Bobcat E32 Mini Excavator (A51691)
2013 Bobcat E32...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
1992 Peterbilt 377 Sleeper Cab (A52748)
1992 Peterbilt 377...
12in Digging Tooth Bucket Excavator Attachment (A50322)
12in Digging Tooth...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
