Question about Yanmar models
   / Question about Yanmar models #1
danno676
Mathews, VA
Couple of Wheel Horses, looking for a real one
Hello, new member with my first post. I am new to the tractor world, though I have always had some nice Wheel Horses and of course the friends that would let me borrow their Kubotas.
I have been looking for a CUT for a few months now, everything from Kubota, to Mahindra to the refurbished Yanmars. From research on this, and other, forums I have decided that if I go with Yanmar I will be getting one that has been refurb'd by Fredericks.
I have narrowed it down to these:
ym2210d 26 hp powershift 2194lb
ym2310d 28hp powershift 2127lb
ym2420d 29hp powershift 2723lb
From what I have read, the 2210 has more low end torque than the 2310 with it's 2 large cylinders, vs the 3 smaller cylinders, which would be better for running implements at lower engine rpms but higher pto gear range (I assume that can be done), also better for good low end grunt.
What I don't understand is how the 2310 can weigh so much less than the 2420 (and still less than the 2210). According to all the sites and info I can find, the numbers I have listed are correct. The specs for length and width of the 2310 and 2420 are the same so it appears that they may share the same chassis. How can the 2310 weigh 600lb less? Is the 2310 built less "heavy duty" than the others or is the 2420 just built that much better. I know there is a few year gap between the 2210 and 2310 so materials and construction are going to be weighing factors..just hard to fathom the 600lb difference.
Here is a link that has all the specs at a quick glance Yanmar tractor specifications
I am back and forth about how heavy of a machine I want for the light yard work I plan on doing, though with the FEL the added weight would be nice.
Any input on "better machine" would be appreciated as well too.
Thanks!!
I did find this thread, very interesting http://www.tractorbynet.com/forums/yanmar/81255-2-model-yanmars.html?highlight=2420d
I am still interested to know what the differences are between the xx10 and xx20 tractors, so far I have gathered:
wet brakes
shifter on column
heavier transmission and axle housing (just housing or are the internals better?)
Wet brakes are nice but a light tractor is nice too, you can always add weight if you need it but you can't but a put a tractor that is built heavier on a diet, so to speak.
   / Question about Yanmar models #3
Welcome to the forum. :welcome:
I think you have pretty much answered your own questions. I think a good portion of the 2420's have power steering also. Personally,with this size tractors, I would consider more weight a big plus. Just my opinion.
Thank you for the welcome!!
Yeah, I am pretty sure I amswered my?'s for the most part, search button is your friend.
I still am curious if the transmission and differential internals are any beefier in the 20's vs the 10's. I agree with the weight, especially when it comes to pulling ground engaging implements and for overall traction.
Still on the fence between one of the above 3 and a Mahindra, I've been looking at the Max 28xl, shuttle shift with FEL. Much smaller than any of the above but just as powerful and capable (on paper anyway), the Yanmars will probably outlast it though.
   / Question about Yanmar models #5
Welcome.
I think we have discussed this or a similar weight issue. I think some of those numbers are proven screwy. Some are dry weights and you see a wide range of weights even depending on site for the YM2000, which i have. Its just a tractor sure you can ballest it in many ways but were all talking operational weight no ballest...how can you see numbers that range 200-300#s??
I think Kenmac with his 3110 and some other similar tractor had a weight difference (member i was talking about is the first of my post). I think a similar frame tractor weighed way less than his tractor or something and they decided it was not real.????
I would say get the larger one if you can justify the extra $$$. there all pretty similar and more power is good.
I dont think you will see enough difference in the 2210 and 2310 to worry about.
   / Question about Yanmar models #6
I think the 2210D and 2310D will be very similar for you. I wouldn't worry about the difference in torque between the 2 vs 3 cylinder models. With the Powershift transmission you can just select a lower gear on the move, and the difference between the two motors won't make any difference. Recognize that Yanmar replaced long-selling 2 cylinder motors with their 3 cylinder versions, so they had to be of equal capability or better. A similar comparison might be the LS series Chevrolet small block V-8s replacing the 40 year old small block: It has the same job to do, and is replacing a long-respected motor. I like the two cylinder engines myself, but there is no reason to get hung up on 2 vs 3 cylinders as a selling point by itself, in my view.
There is no advantage to running the engine at lower RPM with a higher PTO speed unless you are only operating a very lightly loaded attachment. For tilling or mowing (I don't know anything about snow blowing or using a water pump on one, but I'm sure they are similar) you want to be at the rated RPM for the engine to prevent lugging and bearing wear. It won't hurt these motors to run at their rated RPM. It is actually better for them.
I think you should make a list of what you would like to get out of your tractor, in terms of specific tasks you see it doing, other issues (Do you want to loan it out? To NOT loan it out? Any other operators besides yourself, your mechanical aptitude/interest, foreseen time owning the machine etc) and then reassess. If you are trying to do disking, rough field mowing, plowing, etc, and have the space, PTO horsepower, bigger tires and heavier weight matter more than other factors. Doing work on manicured landscape will get better results from a fancy mower than any tractor.
What models of tractor have you borrowed, how did they perform for you, and will your jobs be similar in the future?
Good luck, and welcome to the forum. I hope you find what you're looking for!
   / Question about Yanmar models #7
Be careful. The weight you posted Matches my list. I was looking at your list and just happen to look at the Ym2000 specs. and there wrong. Big time. There is no Eng. HP. difference in the 2000,D,Or BD.
   / Question about Yanmar models #8
In the notes that I have the 2420 D weighs in at 2215 pounds. you also asked what the difference was with the 10 and the 20 series and that just indicates powershift whether it's on the floor are on the column. My 2020 D has the power shift on the column.
   / Question about Yanmar models #9
Those three are close enough in capability that I think it comes down to spend a little more for a later model and get more advanced features. Or save some money on a quite satisfactory model. (2210D).
I like powershift next to the steering wheel and feel it is worth paying more for. This really is a convenience and a productivity improver. And power steering if available is a huge improvement, worth the considerable price jump. Particularly if you are going to mow, rototill etc in tight spaces these both are important features.
As for engines - my two-cylinder YM240 (nearly a twin to the 2210) seems more tiring after several hours on it due to the intense clank of its primitive 2-cylinder, high torque engine. Hearing protection is essential, but I still feel a bone-shaking thump with each firing that isn't present on my smaller 3-cylinder YM186D. For shorter operating runs, this probably doesn't make any difference.
Me personally, I choose to live reasonably simple and just buy what I need to get my specific tasks done. The 2210D should be sufficient. But I also understand paying more to buy comfort and simply pride of ownership. Maybe the Mahindra at higher cost, possibly some trips back to the dealer before it is flawless like you intended, and a forecast of earlier replacement, would be worth it to you just for its comfort and features. That alternative has certainly crossed my mind but its not worth an additional $10~15k to me compared to what I use now. Your choice! :)
All very good points, thank you everyone!!
I figured this would come down to "just pick one", I just wish there were some Yanmars around me that I could try out.
The 2 Kubotas that I borrowed were both very basic older machines. I really have no use for cup holders and other such fancy crap..just stuff that can break. One of them was a very small, SCUT, 2wd with rear scraper blade and turf tires. I quickly realized it's limitations and borrowed another Kubota L2350DT(4WD) with FEL and ag tires. It did great, plenty of power, hydraulics were a bit weak though. The L2350's specs are pretty close to Yanmar's 2010 (tractordata has them rated at 20.5hp pto) so in reality any of the ones I am looking at will definitely do what I want and then some. Suppose the 2 cylinder would be much noisier, I have a 2 cyl Yanmar in a sailboat and it is very clacky. The 2310 would be a step up from the borrowed Kubota.
My only intentions for use are bush hogging a few acres once a month or so, driveway maintenance, post hole auger and other light tasks like moving a 3500lb camper after use that I have been using a Wheel Horse to move (that's an interesting task).
If I went for the 2420D I would be about 13k delivered, a full 2200 less than the Mahindra (after VA sales tax).
The Mahindra dealer has a 2013 demo with 13(ish) hours on it at a good deal. I figure that it should have the bugs worked out by now and the 5 year warranty would not start until it's purchase date. However, I am quite sure that overall quality of the Yanmar is much higher, as the resale value (and ease) further down the road.
Scotty Dive, awesome info with the weight, that seems to be much more in line with the rest of them. Fredericks told me that the only difference between the 10's and 20's was the location of the shifter, then I saw the weight and wondered.
This is a great forum
New Land Hero Mini Excavator (A53002)
New Land Hero Mini...
U56 ELECTRIC FIRE PUMP (A51406)
U56 ELECTRIC FIRE...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
New/Unused 10ft Workbench with 15 Drawers (A51573)
New/Unused 10ft...
