fredhargis
Last Friday's snow was quite a bit more wet than normal. After going down my drive and getting about 2/3's of the way back my thrower's chute completely clogged. I hadn't caught any icy slush, it was just the wet snow had packed it closed. I was close enough to done to just finish up with the FEL (throwers a 3PH model). I then pulled it in the garage, cleaned the chute and removed what I guess is a rock guard. Then went out and cleared the drive to the barn, about the same distance as before, with no clogs or problems. So, I'm thinking about either just leaving the guard off, or at least pulling the fingers off of it. In the pics you see a photo of the guard laying on my assembly table. Then another photo of it mounted on the chute, showing how the fingers project into the chute....which is in my simple mind, at least part of the reason the chute had clogged. The blower is a Kubota B2789 if that's useful...so before I amputate or straighten the fingers (or worse) what think?
