stuarth
I would like to ask for some pictures and the directions of the skid shoes for the BX2763A blade and how they should be adjusted for height. A picture is worth a thousand words.
Here is a picture of my BX2763A blade and how i have the skid shoes adjusted for height. http://i283.photobucket.com/albums/kk286/lb59/100_2316.jpgI would like to ask for some pictures and the directions of the skid shoes for the BX2763A blade and how they should be adjusted for height.
1*I know it is, but I can tell from the picture there are at least 4 washers on top. The other side would be the same. I will take a look at the tractor and let you know when i get a chance.LBrown59,
Thanks for the picture but
1*its hard for me to see even with the zoom.
2 *Do you have any washers below the bracket or are they all on top?
3*How many pairs or halfs do you use on each shoe?
I just got a few minutes free so I went out to the building and looked at the blade.Thanks for the info, it looks to me you have no washers below but like we agree it is hard to see. I have not attached the hitch to the BX yet so I can't adjust the shoes while mounted but I wanted to try to get it close as I reassemble the shoes and brackets after paint. Thanks and I look forward to hearing back.
New information for stuarthI just got a few minutes free so I went out to the building and looked at the blade.
I have 2 washer on the bottom and 6 washers on the top on each shoe.
Hope this helps ya out.
I found that once I got the skid shoes set on my old Bolens i never had to touch them again so I assume that would also be the case with the BX1500.Depending on the makeup of your driveway, you may be adjusting them some with the weather. I have a crushed shale driveway and when it is soft, the blade needs to be raised a litlle more in order not to dig up the driveway when to shoes sink in somewhat. Once the driveway freezes up, I lower the blade all the way down so it is essentially scraping as much packed snow and ice off as it can. The worst time is in the spring when everything gets mushy; a heavy snow then usually results in much gouging of the softened driveway.
