Snow Question about PTO shafts
   / Question about PTO shafts #1
Old School
Bronze Member
Wisconsin
BX2200D, JD950, JD X324
I have a b2650 front mount snowblower that I've used for several years with no issue until the very last snowfall last year. The mid pto shaft goes from the transmission to a subframe mid shaft, for lack of better words. The mid shaft mount broke and needed to be welded. It appears the mount broke because the mid pto shaft isn't perfectly balanced. The mid pto spins at speeds up to 2000 rpms. I tend to run the engine at 3/4 throttle because it feelings like I'm over driving the pto and snowblower at max power.
Is it normal to get pto shaft vibrations at those speeds? Am I over driving the mid pto causing the vibration which lead to the mount braking?
Are pto shafts normally balanced and how do you go about balancing a 2 piece pto shaft?
Before I go out and buy a new mid pto shaft I figure I'll ask these questions first. Thanks
   / Question about PTO shafts #2
I would price the new shaft for comparison first. Then look in yellow pages for "drive shaft balancing". If none appear in yellow pages, look under "Truck Springs" and they may point you to someone in your area.
   / Question about PTO shafts #3
2000 rpm isn't all that fast to generate a vibration unless it's way out of balance. If I had to guess, any vibration present is caused by misalignment or the shaft being bent.
   / Question about PTO shafts #4
I just wonder if the vibration is why you thought you were overdriving the setup?
Take Care,
Doug in SW IA
   / Question about PTO shafts #5
What Causes PTO Vibration?[/url]
That sounds right to me. Have you checked for wear? Slop in the bearings will also cause vibration when the shaft goes off-center. Also, be aware that there is a correct and incorrect way to install the yokes (phasing):
http://www1.agric.gov.ab.ca/$department/deptdocs.nsf/all/eng5241
I called a couple driveshaft shops and they said they didn't have the equipment to balance the shaft because of the proprietary 10 spline yokes.
Thanks. That article is helpful. I'm thinking the shaft might be bent and thats why the guy sold it. I ordered a new shaft yesterday but I'm still not done trying to problem solve the one I have.
UNUSED MOWER KING SSAB72 ANGLE BROOM (A51244)
UNUSED MOWER KING...
2025 GIYI Single Cylinder Hydraulic Grapple Stump Bucket Skid Steer Attachment (A50322)
2025 GIYI Single...
2015 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A52141)
2015 INTERNATIONAL...
2017 JOHN DEERE 624K-II WHEEL LOADER (A51242)
2017 JOHN DEERE...
2015 Ford Explorer AWD SUV (A48082)
2015 Ford Explorer...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A51243)
2000 TRAILKING...
