question about kioti headlights
   / question about kioti headlights #1
johnpenny
Hello I have a ck20 , one of the headlight bulbs is broken, is this a dealer item or can i purchase it at auto parts store or maybe tsc. Thank you for your help with this post and prior post also
   / question about kioti headlights #2
They are a standard H4 bulb. The only difference I can see is my CK30 manual advises to use a 25/30 watt bulb, where normal vehicle bulbs are 55/60 watt bulbs for low/high beam. I don't know if the wires aren't heavy enough or they are worried about heat build up. Maybe an auto parts store would have the lower wattage due to them being a standard bulb design.
   / question about kioti headlights #3
I had one burn out of my CK 30 last fall and I put 60w watt bulb in it and I have had no problem so far. If you look at the book they say for Europe
use 55w/60w and for US use 35w/35w . Sure can see now.
The Fox
   / question about kioti headlights #4
There you go. If the 60 watt works, then you can find them at Walmart or any other similar store and probably save a few bucks compared to an auto parts store. Thanks for the input Fox. Maybe it's time to change mine and be able to see better at night.
   / question about kioti headlights #5
Actually my local autoparts store is cheaper than Walmart for things like that. Surprisingly a lot cheaper.
thanks for your help will be going to napa tommorrow
UNUSED INDUSTRIAS AMERICA HI100T HYD TILT LAND LEV (A51247)
UNUSED INDUSTRIAS...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
LMC LOT NUMBER 142 (A53084)
LMC LOT NUMBER 142...
UNUSED FUTURE SF60 HYD MAST W/ 60" FORKS (A51248)
UNUSED FUTURE SF60...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2013 RAM 4500 (A50323)
