question about H bracing and X wiring
   / question about H bracing and X wiring #1
moloss
Alabama "Heart of Dixie"
share Kubota M6800
do y'all use heavy wire in a X pattern around your H bracing? why or why not? I can't help but think it would make it stronger but is it worth the time? thanks Chris.
   / question about H bracing and X wiring #2
I do not "X" wire brace my single or double braces. I use a single wire, crimped on the bottom and with a Gripple on the top for my singles and a looped wire with a strainer on my doubles.
Rather than standard 90 degree corner bracing, some of my corners are "rounded". IE; I set my H braces a few feet back from the corner then connect with a cross post at a 45 degree angle. I then "X" wire the corner but still use singles on the line bracing. Makes for a nice solid corner.
The rounded corners are good for when the horses act up and make navigating the outside corner easier with a vehicle.
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A53843)
HYDRAULIC TILTING...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
THE HANDLER II MIXER UNIT (A53843)
THE HANDLER II...
WOOD GRABBER FOR MINI EXCAVATOR (A53843)
WOOD GRABBER FOR...
