Question About Greasing Kubota Loader Control Linkage
   / Question About Greasing Kubota Loader Control Linkage #1
VaBeekeeper
King George, VA
2016 Kubota L3901 HST with LA-525 front loader
Hi all,
The manual for my Kubota LA-525 loader is pretty clear, with the exception of one thing. It says that in addition to all the grease zerks, I should also grease the "loader control linkage" (or something similar- the manual is in my barn). When I look at the loader control, it's not immediately apparent to me what specific part they are talking about. I've seen some other posts about greasing the linkage. Some say that I should remove the plastic cover and use a can of spray grease to lube what I find in there; others don't say anything about removing the plastic cover, but advise me to just aim the grease can from below. I find it difficult to imagine that Kubota would design their products to require disassembly in order to perform routine lubrication, but I don't know anything. Can someone, ideally a mechanic, shed some light on this topic? Pics would be helpful.
   / Question About Greasing Kubota Loader Control Linkage #2
Control linkage is your "joystick" for your loader. There should be some rods and heim joints in there, or something similar. A blast with some Fluid Film or white grease should suffice to keep things smooth and rust free. You shouldnt have to disassemble, just spray form the bottom (at least on the BX). if you have to remove a cover it probably wont be that bad either, remember, you only have to do this particular lube a couple times a year at most (not every time you lube the loader, every 10h)
   / Question About Greasing Kubota Loader Control Linkage #3
Arg-g-g!
Thanks VaBee & Scooby, I didn't know there was some "loader control linkage" that needed periodic service. Am going on 5 years of usage and never though about it. Maybe I'll remember to look into it next time greasing.
   / Question About Greasing Kubota Loader Control Linkage #4
I wouldnt sweat not doing it OB. Lubing that linkage really isnt a super important service IMHO. Its more just to keep things loose and prevent corrosion. Plus its in a pretty sheltered location too, so it doesnt see that much exposure to the elements (on the BX at least)
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
2019 Toyota Corolla Sedan (A51694)
2019 Toyota...
NEW Mini Excavator Fixed Thumb Attachment (A53002)
NEW Mini Excavator...
2006 Ford Fusion SE Sedan (A51694)
2006 Ford Fusion...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
