Question about getting my computer to recognize my Garmin Nuvi 265W GPS
   / Question about getting my computer to recognize my Garmin Nuvi 265W GPS #1
Dozernut
Veteran Member
South Eastern Illinois
ZD1211, RTV900, LX2610SU and a SVL65 CTL
We have a Garmin Nuvi 265W GPS that we have owned for two years. I wanted to upgrade the maps and I purchased the life time map upgrade for it. I had trouble getting the program downloaded but with the company's support was able to get it done.
I cannot get my computer to recognize the Nuvi to down load the mapping program. I have followed the companies suggestions, traded USB cables, rebooted and done a little cursing.
Maybe someone could give some advise or maybe another owner who had a similar experience could tell me how they resolved it. It seems this is a common problem with the Garmin. Thanks!
   / Question about getting my computer to recognize my Garmin Nuvi 265W GPS #2
   / Question about getting my computer to recognize my Garmin Nuvi 265W GPS #3
download Garmin Communicator. It is the Garmin program to get the computer to recognize all their products. It is a free program from the Garmin site. After installing, just plug the NUvii in and it will be connected.
Thanks for the replies, I appreciate your help!
J.J. no, the computer does not recognize the Nuvi. I have tried all the cables I have and every USB port on the computer. I will pick up a new cable in the AM, but I don't believe it will help, we will see tomorrow.
IkeRoberts, I have downloaded five different versions of the Garmin Communicator, but none worked. A search of the net yielded that I am not alone with my problem. A computer is just about the most frustrating thing but when working right they are wonderful.
   / Question about getting my computer to recognize my Garmin Nuvi 265W GPS #5
Have had similar problems. As suggested it is probably the cable. I have found new cables included in a new GPS's that were bad.
   / Question about getting my computer to recognize my Garmin Nuvi 265W GPS #6
Try on another computer just to make sure it is not your computer. It might be a bad GPS or cable. It should make some sort of noise when plugged in to a computer and a message may pop up about a device found, even if it does not have the driver for the device. Some Garmins will turn on when you plug in the USB cord to the computer. Not sure about all as I have only touched 3.
IkeRoberts suggestion of the Communicator software is also a good idea. I have had frustrations "seeing" my GPS and fresh Communicator software helped.
   / Question about getting my computer to recognize my Garmin Nuvi 265W GPS #7
I just bought the nuvi 50lm, it uses the garmin express program. Is it a usb issue? or from the unit itself.
   / Question about getting my computer to recognize my Garmin Nuvi 265W GPS #8
Dozernut,
Here's a few things to try... hope they help.
First, what operating system is your computer running?
If its Windows (any version) have you run Windows updates on it recently?
If you have not run Windows updates, you should to bring it up to the most current.
Have you tried a different USB port on your computer?
Sometimes the ports on the front go bad. So don't just try the next port over. Try one of the USB ports in the back that resides directly on the motherboard if you haven't already.
Have you tried a different USB device in your computer (like a thumb drive, camera, etc...)?
It could be your computer is having USB problems.
Try a different USB cable to the GPS.
Try the GPS on a different computer.
Hope those help and forgive me if you've already done all that.
I have a Garmin (forget which model) also and it is SLOW to recognize in my old PC, and even slower to update the maps, but with a LOT of patience it eventually recognizes and runs everything.
On the road, the GPS is nice to have. :thumbsup:
I used to laugh at people that used GPS. I was a Boy Scout. All I needed was a map..... guess what genius? A GPS is a map! DOH!!! A lot of maps. A really good map. An probably more up to date than the 8 year old atlas smashed under the front seat. :laughing:
I still plan out my trips on the home PC, write down which main highways I want to take, then plug in my destination to the GPS. I memorize the route for the most part, but the GPS really shines around cities and large urban areas. Also, the restauant finder works pretty well. I don't care if I get lost, but going hungry is a catastrophe! :licking:
   / Question about getting my computer to recognize my Garmin Nuvi 265W GPS #9
I just had the same problem but I downloaded the Express Program from Garmin and that seemed to do the trick. Up to that point the whole download thing was A BIG PITA.:confused: Each time you contact Garmin you get a new person and have to start over again, SUCKS.
Thanks again to all who responded I truly appreciate your help. I am still fighting with this thing, I have tried all USB ports front and back and three different cables. I can get the computer to connect to the SD card in the Garmin but it will not recognize the GPS it's self. The computer down loads my digital camera, uploads to the I-pod, handles wireless headphones but will not accept a Garmin Nuvi. I will keep trying, thanks again!
2015 Kenworth T880 (A55973)
2015 Kenworth T880...
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2016 Ford Transit Connect Cargo Van (A56858)
2016 Ford Transit...
2022 CATERPILLAR 299D3 SKID STEER (A52709)
2022 CATERPILLAR...
