question about duty cycle
   / question about duty cycle #1
HCJtractor
Veteran Member
upstate South Carolina, Greenville
Kubota M6800, Massey Ferguson 240
I have a Miller 211 Mig that I am learning on . I understand the concept of duty cycle, but am unsure what happens to this particular welder when it is exceded. Does the arc just weaken and you just sense a lack of power? Or does the machine have an automatic cut-off or signal that it is time to stop and let things cool? In other words, how do I know it is time to slow down and wait? I hate to ask stupid questions but hey, I admit I am clueless. Thanks to you guys who are willing to share your knowledge!
   / question about duty cycle #2
If I remember correctly, it should have an automatic cut-off.
Yep, it does. Found it on my spec sheet:
"Thermal overload protection shuts down the unit and activates over temperature light if airflow is blocked or duty cycle is exceeded. Automatically resets when fault is corrected and unit cools."
   / question about duty cycle #3
How do you like your 211? I keep bouncing back and forth on buying a Millermatic 211 or an Everlast I-Mig 200.
   / question about duty cycle #4
I've got the 211. I love it.
Had a Lincoln 135P, 110v prior to the 211.
There is no comparison. The 211 will do most
everything that I will ever want to do with it.
I have welded 5/16" steel with no problems. I
know that I could even do heavier steel, just haven't
had that opportunity. I mostly just make my own
repairs and some light fabrication.
Greg
   / question about duty cycle #5
I've had inexpensive, low duty cycle stick machines all my life, never paid any attention to the duty cycle, never stopped welding cause I thought I was going over. No worse for the wear as far as I can tell? I'm sure the modern MIGs may be more susceptible and have some type of built in protection.
JB
   / question about duty cycle #6
all my machiens cut out when duty cycle is exceeded.
soundguy
   / question about duty cycle #7
[Hijack]
I am going through the same debate. Everybody who has the 211 loves it, all who have the I-Mig love it. I suspect you can't do wrong with either. For me it comes down to... do I want have a relationship with a local vendor for supplies/service (Miller) or save money, have more features, 1/2 the weight, but need ship unit out for service if needed, mail order consumables. (Everlast) I'm getting tired of doing the pros/cons, I am about to toss a coin.
[/end Hijack]
   / question about duty cycle #8
I also have a Miller 211 and I can say I love it also. I had a lincon sp 100 it was a nice little welder but nothing compared to my 211. Glad I bought the Miller. On the question of duty cycle as others have said it will shut down but, leave the power on so the fan keeps running. I welded up a tube for my bucket 68'' long almost continuously. The ground cable got a little warm but, it never shut down.
   / question about duty cycle #9
If you read your manual on the 211 or any other welder it will tell you what your duty cycle is. The 211 is probably 20-30% at 211 amps or 30-40% at 150. It just means how many minutes out of 10 you can weld before the machine starts to heat up internally. 30% = 3 minutes out 10 arc time. Dont worry about duty cycle until it gives you a reason to. Then you will live with what you get or you will buy a more industrial type machine.
   / question about duty cycle #10
150A at 23.5VDC, 30% Duty Cycle (230V)
90A at 20VDC, 20% Duty Cycle (120V)
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
John Deere 848G Grapple Skidder (A52384)
John Deere 848G...
UNUSED AGT QUICK ATTACH 72" VIBRATORY ROLLER (A51248)
UNUSED AGT QUICK...
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
1991 KALYN SIEBERT 60 TON LOWBOY TRAILER (A51247)
1991 KALYN SIEBERT...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
