Question about drag harrows
   / Question about drag harrows #1
Stromeyer
Rochester, NY
Deere 4600
Hi all,
I'm sure this has been covered before, but I am looking at chain harrows and the like for pasture maintenance and breaking up manure in the field. Seems likes there is a huge range of prices and types to choose from. Possibly thinking of building my own with some old heavy timbers and chain link fence. Any recommendation on brands or types.
By the way this will be pulled by a Deere 4600, so I am thinking about 8' width.
Also has this forum come up with a name for the disease that causes otherwise sane individuals to spend too much time on TBN reading about tractor attachments that their significant others won't let through the door?;)
Thanks,
Willie
   / Question about drag harrows #2
Part 2.
Nine years later still no name,for addiction effects many in different forms.
Once TBN in your blood there ain't no cure...just therapy. ;)
   / Question about drag harrows #3
Hi all,
Thanks,
Willie
I've devoted my life to the study of this disease. As of this time, no known cure.
But may I suggest a new therapy we've developed....Buy that chain harrow!
It is better to ask for forgiveness than to seek permission sometimes.
   / Question about drag harrows #4
your best bet is to go with a two way chain harrow.
I wouldn't try to make your own, I paid around $400 for my 8' x 8'. You can turn them around to do less damage for grass paddocks, etc... or have them go deep for doing the driveway, horse paths, etc...
I made a set once with chain link and it worked for about 20 minutes.
Also, don't go with the lift from the harrow manufacturer. It's bulky and very expensive. Instead you can buy a boom pole instead and hang the harrows from that.
You can also go with diamond, sold harrows. The idea is that they chatter and break up the clumps. I've never liked them myself, escpially when the ground is inconsistent.
   / Question about drag harrows #5
I got one of the "small pasture harrows" from Wingfield
Wingfield Flexible Chain Harrows - These high quality chain harrows are perfect for a mid-size operation. The drag harrow (Maxi Drawbar) or 3pt frame model (MaxiLift) utilize our fullest depth of section (7.5') to get the job done in a single pass!
They're pricey but really well made. The more weight - the better the harrow works as it doesn't bounce over dirt clods or hard ground.
I built my own frame for it with a 3-point hitch attachment. That cost me about $80 in materials + 1 weekend.
   / Question about drag harrows #6
I made a drag harrow out of heavy 4" x 6" angle iron. Used 3 pieces about 7' long. Drilled and placed 3 heavy eye bolts, 1 in the center and 1 towards each end. Connected all three in parallel about 3' apart with chain and also ran chain diagonally and criss-crossed in a web pattern between each angle. Where one chain crossed another, I linked together with a lap links or quick links. Of course attached a loop of chain at the front to connect to the vehicle. I found that if I connect this with a heavy 3 or 4" towing strap about 6' long to the hitch of a tractor, jeep, or truck, this provides some shock absorption if you snag something. Only problem is the turn radius. Sometimes in a narrow food plot, I have to unhitch and drive over it, turn and reconnect. The cost was very minimal, chain, links, and eye bolts, and usually buy cheap angle at a scrap yard. It has no teeth so it doesn't dig, but it will level the dirt big time! It also varies in action depending on if the edges are down or up. I have drug this probably 30 miles for years, and it shows no sign of wear. I have thought of welding short hardened spikes to one piece to allow creating a seed bed. After disc harrowing, when the soil is very uneven, a pass with this will leave it as level as a ball field. We also use it to cover seed, by driving pretty fast so it doesn't dig in too deep. It does a great job of leveling tires ruts in dirt roads. We drag is around as we travel across our property just to keep the roads looking fresh. It's heavy, takes two to lift it, but we rarely need to. Just unhitch the chain and let it lay.
   / Question about drag harrows #7
I had the same issue, what to use to bust up the horse manure in the pastures. Ended up getting the very same drag you see used on baseball fields. Was less money than a regular drag harrow. It does not damage the grasses at all and does a nice job!
I also tried using a section of a gate for a chain link fence. Did a so-so job and lasted about a month.
Good luck!
Phil
VA
   / Question about drag harrows #8
Hi all,
No name but there is help:
1. Admit you are powerless over attachments, that your life has become unmanageable.
2. Believe that a power greater than yourself can restore you to sanity.
   / Question about drag harrows #9
Thanks for the info everyone.
After reading the links about tractor addiction, I must step up to make a confession.
Last year when my wife was on vacation for a week with a friend, I did a little implement shopping.:D
She didn't find the rotary cutter for a few days. I spend those days building a dog house for myself to move into.
2016 Komatsu D65EX-18 Dozer (A42203)
2016 Komatsu...
2015 INTERNATIONAL LF687 (A45046)
2015 INTERNATIONAL...
2018 INTERNATIONAL RH613 DAY CAB (A45046)
2018 INTERNATIONAL...
DEWALT 23LB DEMO HAMMER (A45333)
DEWALT 23LB DEMO...
2015 WESTERN STAR 4900 SF (INOPERABLE) (A45333)
2015 WESTERN STAR...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A44572)
2014 Ford F-150...
