Rivendale
I am in the market for a tractor and looking at a few. I have a question about the
John Deere
turbochargeddiesel
3-cylinder
liquid-cooled
179 ci [2.9 L]
This is the engine is in a JD 5400 that I'm considering buying. I am also looking at a NH in the same HP Range 75hp engine , and low 60s PTO.
The engine in a New Holland tractor im looking at is 3.9L and 4 cylinder but in the same HP range.
The engine in the JD5400 seems to be basically an older version of the same size engines used currently in the 5045D through the 5075E. JD tweaks with fuel delivery and a few other things right? and uses the same engine across a broad spectrum of ranges. Looks like they did the same thing in the 90s with that series
I guess to make my question simple... seems to me that the engine in the 5400 (versus a larger displacement and extra cylinder) would "work" harder to generate equel HP as an engine with hight displacement and an extra cylinder... am I right or is my thinking way off base?. I don't want to turn this into a brand thing. I really like JD but I want some advice to be fully informed on my purchase.
The heaviest workload it will do is pull a medium duty batwing (woods MD315) and pull a medium sized round baler on flat ground. (the 5400 im looking at is 4wd) The tires are loaded and I would ballast probably because I have a couple steep banks that I would mow with the batwing.
Help
John Deere
turbochargeddiesel
3-cylinder
liquid-cooled
179 ci [2.9 L]
Help
