question about a plow
/ question about a plow #1
ronbo3
Bronze Member
DFW, Texas
Kubota L2800DT
I am looking at buying a used Dearborn 2 bottom plow, and I would appreciate any comments/opinions on this brand. I have heard that the older Ford and Ferguson brands are "better" than the new ones like TSC sells, but I don't know anything about the Dearborn brand or plows in general. It seems to be in good condition, with both moldboards and points in good shape, and with little rust. Is there anything else that I should be looking at?
/ question about a plow #2
They were good plows. Lots of adjustments to make, which will be important.
Some good information on this forum, that a search should bring up for you to read.
/ question about a plow #4
We have a 2 bottom Dearborn plow ourselves. It's a fairly easy plow to use once you have it set up correctly and understand the basics. We have always used ours without the colter's and it works well for us.
There is a lot more information on your plow here.
/ question about a plow #5
I have a older dearborn 2-bottom plow and it has worked wonderful for me. It has held up through some rough plowing by me and I bet it has seen much worse in years past! They are good solid plows. I paid $200 for mine three years ago and I do not regret it one bit. I hope this helps.
Dan
/ question about a plow #6
What you have heard about the old and new is correct. Check to see if it is like Ken said and you should be alright.
Thanks guys for the info. PineRidge, that link was great, and I bookmarked it for future use. I will buy the plow ($200), and give it a go, knowing that if something doesn't work, I can find the answers from TBN. TBN is a great place!
/ question about a plow #8
Ronbo3 glad there was some info there that helped you. Those links are our way of payback for the things that we have learned here at the TBN site. /forums/images/graemlins/grin.gif
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
Gravity Box (A65640)
Wolverine Brush Cutter BC-13-72W Skid Steer Mount  (A62679)
Wolverine Brush...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A65054)
(INOP) 2013 MACK...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2014 BOBCAT T650 SKID STEER (A65053)
2014 BOBCAT T650...
