Question about a hose on my TC35D
   / Question about a hose on my TC35D #1
LabLuvR
SC
Kubota MX5400
I've had the tractor for a year, but today I noticed this hose moving some as I was using the machine. Not sure if the lower end of the hose should be connected to something or not. The hose I'm referring to is the one in the picture that I have folded over to make it more visible. It is connected somewhere at the top of the motor and comes down by the fuel filter. Should it be connected or does it just dangle loose? Thanks!
   / Question about a hose on my TC35D #2
I can't see your photo. It says, "Sorry, this person moved or deleted this image." :confused3:
Sorry about that, let's try this one:
After thinking about this some more, part of the hose looks to clean to be left dangling down. Hmmm...
   / Question about a hose on my TC35D #5
It looks like part of the crankcase vent we had on older models. I think mine is metal on my TC45D. I'll check later today and tell you what I find.
Mine is an 04 model if that helps. I went back out there today and looked over the top part of the engine to see if it would fit anywhere and I had no luck. Maybe it does just hang loose. Thanks Jim
   / Question about a hose on my TC35D #7
Yes, it's the crankcase vent. It comes off the valve cover and hangs down beside the hydraulic lines. Mine is not metal, just plastic tubing like yours. Just set it back straight down and don't worry about it.
Super! I don't know how it has stayed so clean though. Thanks again!
2022 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2022 CATERPILLAR...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2023 JOHN DEERE 8R370 LOT NUMBER 219 (A53084)
2023 JOHN DEERE...
2018 FORD TRANSIT T250 CARGO VAN (A52577)
2018 FORD TRANSIT...
LOT NUMBER 51 (A53084)
