QA Template
   / QA Template #1
Stormchaser312
Leeton Missouri
3510 Mahindra
Hello All,
I have a skid steer type QA type FEL and want to make a set of forks, I all read have the forks the ones with the 1 1/2 hole in them for the bar that mounts it the unit. What would like to know if any of you guys & gals have any input on how I should go about constructing the mount that mates to the loader?
Thanks Ken
   / QA Template #2
Ebay, quick attach plate, usually around 100 bucks or so. I bought mine to make a grapple with, fits great.
   / QA Template
   / QA Template #4
Ken if you're thinking about making a set of QA plates yourself its a pretty straightforward job. The only problem that I can see is most of the plates are thick steel that has been bent or formed into shape. Although I guess its possible to keep all parts flat and straight and just weld them together.
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
100 GAL FUEL TANK W/ PUMP TOOLBOX COMBO (A52472)
100 GAL FUEL TANK...
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2019 PETERBILT 567...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
BAUER ATD-750 VERTICAL HYDRAULIC PIPE HANDLER (A52472)
BAUER ATD-750...
2010 FREIGHTLINER M2 BUSINESS CLASS CAB AND CHASSIS (A52472)
2010 FREIGHTLINER...
