QA pins vs Skid steer
   / QA pins vs Skid steer #1
Slippy
Veteran Member
Ohio
Mahindra 6000 4wd; IH x2; NHTC40DSS; International 1086; JD 5115M
In looking at MUSA web site they show QA adapter pins and QA adapter skid steer. I guess I know what a skid steer QA is because I have it on my New Holland. It has two levers on it and you simply pull up on them and it releases the bucket. But what is the pin set up and is it unique to Mahindra? I have the ML 264 loader on a 6000.
   / QA pins vs Skid steer #2
The pins are what I have. I would recommend the skid steer type. Mine are now 4 years old and sometimes end up seized up with corrosion. I usually use a t post to pry them loose. Seems maybe the pins are a little bent too. I can't imagine the difference in price would be much and the skid steer QA opens a whole basket of other goodies.
The pins have handles on them that are designed for you just to pull them up and twist to release attachment. It seldom works that way after 4 years though. I would add too if you aren't careful you'll end up with the pin handles hund under the lip of the bracket and that's a real pain to untangle.
2017 Ford Explorer (A50324)
2017 Ford Explorer...
2015 FORD F750 BOX TRUCK (A51219)
2015 FORD F750 BOX...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
International Farmall 300 Tractor (A50514)
International...
2023 Vivid EV Golf Cart (A51694)
2023 Vivid EV Golf...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
