puzzled by a cub
   / puzzled by a cub #1
c23380
NC
2008 ck30
I have a 2165 mower and i had pto clutch issues. It would just disenguage and after pressing in the switch and pulling it back out, it would run for a minute or so but still quit. I bought a switch and this did not fix it. I replaced the relay. Local mower shop suggested to adjust the clutch. I did, but that is not the problem. I checked voltage @ the clutch connector, and i have voltage, but no ground. Ground is the blue wire and it runs directly to the switch. The way it is wired, i do not understand how the relay is involved, or even if it is. As i turn on the ignition switch, the relay is closed. It does not matter if the pto switch is on or off. I guess the biggest issue is the lack of a schematic. If i could see a wire schematic, I think i can figure it out. To me it looks as though the prevoius owner bypassed the relay, but i cannt be sure. Does anyone have a cub contact that can give me wire schematics? Thanks to all. Mike
   / puzzled by a cub
Thanks OM. That is exacly what i needed. I just do not understand why the cub dealer did not have this info. Hopefuly monday i will have time to ring out some wires.
Bobcat 22in. Excavator Bucket (A53117)
Bobcat 22in...
2015 Kia Sorento SUV (A50324)
2015 Kia Sorento...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
Ford E550 Bucket Truck (A53117)
Ford E550 Bucket...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
