Putting shingles on my garage
   / Putting shingles on my garage #1
cperky
Middle TN
John Deere 1025r with 120r front end loader, Hustler zero turn mower
I have been building a garage for my home. I have the roof decking and Tar paper in place and am going to start the shingles. I have never installed shingles before. Does any one know how to get started ? And other steps I need to know? Thanks in advance for the great advice I hope to get
Other Info about the Garage:
I will be installing vinyl siding, I have installed the facia boards, The roof is a 4/12 pitch with one foot overhang all the way around I also have two roof vents to install and also have metal drip guards to install. The garage was framed on 16'' centers The pre made trusses are on 24" Centers
   / Putting shingles on my garage #2
Put down the drip guard (edge) and install the vents first. Directions for the shingles are on the back of each bundle. Reverse the first course. I like using lots of chalk lines on the roof to keep me (and the shingles) straight, about every 5 courses. If you built the rest, it's not hard to do, just takes time. Good luck and where's the pic's?
   / Putting shingles on my garage #3
Put on a drip edge, then follow the directions usually printed on the roofing package. One starter row of shingles 'upside down' to get an edge, then a second row with tabs down and tabs at the roof edge. Nail above the slots per the instructions. I then snap a chalk line to get the second row in a straight line after figuring out how much shingle will be to the weather. If 5 inches, then put in a coarse every 5 inches figuring out if the roof is square and adjusting the exposure to balance the rows with the ridge. Keeping the tabs lined up from bottom to top will make a neater roofing job. New shingles sometimes have a random pattern which makes this less important.
I usually do an entire row across the roof, which allows the cut-off shingle on the end to be used as the starter on the next row up.
Hope this helps a bit.
   / Putting shingles on my garage #4
It's a good idea to cut the tabs off your starter course. This puts the glue line at the edge for the first full course of shingle tabs to stick to. Prevents wind lift.
   / Putting shingles on my garage #5
Do you know anyone who's done this before? I'm not saying you can't do it but boy would I feel a lot better with someone who did.
When I did my house I paid a guy who I knew that did it on the side. He ran the show, I learned and the house didn't leak
   / Putting shingles on my garage #6
I added a second floor to my house a couple of years ago and the whole roof was done over with the architectural style shingles. I learned all I needed to know by going to the Journal of Light Construction website. The previous responses to this thread were all correct - the shingles that you buy should have the proper application procedures detailed right on the package.
   / Putting shingles on my garage #7
When I did the roof on a 16x20 shed I just went to the lumber yard and read the shingle package, it told me how many I needed and how to put them on. That was 10 years ago and the roof still looks great and doesn't leak.
Can't say the same for a smaller storage building I bought prebuilt at about the same time. The shingles on it are starting to curl and have a leak that is running down the inside of one wall. Tells me there is a difference in the quality and longevity of shingles.
   / Putting shingles on my garage #8
I reshingled the roof on my prior house, and shingled the 5000 + square foot roof on my new house I just built. No leaks ever.
Why'd I do it myself? I paid one contractor to do the roof of my first house (it leaked) /forums/images/graemlins/mad.gif and the year after he finished it leaked again. /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif and the roof on my prior house was finished after only 10 years because the contractor who did that managed to violate all 3 cardinal rules of roofing. /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif /forums/images/graemlins/mad.gif
This is not rocket science. Dummy's instructions are correct.
Generally
1) make sure the roof is well ventilated (preferably ridge vents) don't forget soffits!
2) Ice & Water shield all valleys and at least 3' (I do 6) up the edge.
3) tar paper everywhere else where there is no Ice & water shield (otherwise yer warranty is void )
4) flash all valleys
5) install drip edge
6) either reverse the first course, or trim the tabs
7) nail the shingles properly (just above the slots)
8) properly flash all horizontal to vertical surfaces (too hard to explain)
9) use new flashing for penetrations like vent stacks.
10) cap all ridges
I think that covers it.
Oh yeah and rent a nail gun. It speeds things up considerable.
   / Putting shingles on my garage #9
I'll second the nail gun rental, makes a hard job almost /forums/images/graemlins/wink.gif easy!!!
Plan on wearing out the knees and behind of whatever pants you are wearing, take it easy and it will be good.
   / Putting shingles on my garage #10
And make sure you have a pair of shoes with good non-slip soles. And most important, work safely. Falling off the roof is pretty painful, I know!!! /forums/images/graemlins/shocked.gif
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A53473)
JOHN DEERE ROW...
2017 GMC Sierra 1500 Elevation Crew Cab Pickup Truck (A51692)
2017 GMC Sierra...
10' DISC HARROW (A51247)
10' DISC HARROW...
RYOBI 40V 15" ELECTRIC WEED EATER (A51248)
RYOBI 40V 15"...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A51247)
UNUSED CFG...
UNUSED LANDHERO MIG-140 WELDING MACHINE (A51248)
UNUSED LANDHERO...
