MESSMAKER
Veteran Member
I need a plug in the garage for my 220 welder. I was hoping to share the 220 coming in for the water heater. The first problem is, how to get around the WH coming on while I am welding and overloading the circuit.I am thinking that I run hot to the welding plug then branch off with a switch on the line to the water heater, so i can just turn it off when I am welding. I just have to remember to turn the power back on.
The second problem is that I have a nice HD extension cord that I use with my generator. It has both 110 and a 220 welding plug on one end. It has a four prong twist lock on the male end. Can I wire up a box that will fit with the 220 wire that I have which just has a red, black and a ground( WH wire). I am a little fuzzy on the neutral on the 4 way. I think I just cap off the neutral and go from there. I would have a working 220 plug, but my 110 plugs will not work, which I am OK with.
