ayelvington
I have a BX-24 with 18x8.5-10 front tires. I got a flat last week right after bragging that I'd had no flats since filling the tires with Slime. It was a sidewall nick, so I wasn't confident with just a patch, and the cost of a new tire was depressing.
These are low-profile tires, and putting a tube in is no trivial task. Here's the skinny.
1. Get the case (tire) off and clean it up.
2. Patch the hole on the inside to keep the edges from wearing against the tube.
3. Put the tube on the rim FIRST.
4. Put the case on the rim.
5. Line up the valve and pull it through the hole. You might want to use a valve tool to keep it from pulling out.
6. Use your handsto work the tube under the edge of the case. This is where having a partner hold the case for you really comes in handy.
7. Seat the other side of the case over the rim.
8. Pump it up!
The big deal here is that you put the tube on the rim BEFORE you put the casing on. There is no way you're going to stretch the tube over the rim if the case is already on and in the way.
Sorry, no video. We were too busy getting it done to hold a camera.
Did I mention that it's a blessing to have a helpful neighbor? It is!
8. Pump it up!
