Put my gooseneck to work!
   / Put my gooseneck to work! #1
KrayzKajun
Bronze Member
Westwego, La 70094
Mahindra 5010 Cab w/ FEL & HD Cutter, New Holland C232 w/ FAE Mulcher
pulled a nice load saturday. picked up some materials for a few landscape jobs have lined up. the back 3 pallets weigh 2800lbs each, 70 bags of topsoil at 40lbs each per pallet. front 2 are mulch 60bags per pallet.
Built for Tough!
nice load there my man!:thumbsup:
   / Put my gooseneck to work! #4
Them are some big stumps. You did not load them with that little tractor did you?
Chris
   / Put my gooseneck to work! #7
Notice the Dodge is sitting level and the Ford is squatting.
Sorry Chris, I had to. ;) :thumbsup:
Both those trucks look great pulling some heavy trailers!
I actually though it was old Chevy when I first looked at it. Did not blow up the pic.
I agree the Ford is squatting a bit but that is 3 times the load them stumps are.
Heck, my F-250 and my GMC 3500 would squat like a pig until I learned more about GVWR's. I ordered my F-350 as tough as it could be. On a late model F-250 for example there is something like 9 GVWR's available. Its so hard to tell what it has without looking at the door sticker. That is a problem with Fords. I know so many people who bought like I did not knowing there is a difference between two otherwise identical F-250's. GM and Dodge keep it simple and only have a few packages.
Chris
   / Put my gooseneck to work! #8
Chris
Both those loads are massive for SRW pick ups IMO
The weight on the ford is not as well distributed, (to much on the tongue) as on the Dodge. But I don't agree that those stumps weigh just 1/3 the weight of the pallets of landscape materials. Those stumps are monsters.
Probably weigh equal, maybe more. Just guessing, but no way just a third as heavy IMO.
JB.
   / Put my gooseneck to work! #9
I agree. I had three 36" white pines taken down and was left with the stumps that were certainly too big for my little backhoe. I had a friend bring over his JD 490D excavator to pop them out. We had a local stump removal guy come in with an old logging truck that he converted into a stump hauling truck and even his boom couldn't lift the stumps. He said he could lift around 4,000 lbs fully extended but couldn't lift my three stumps so we had to load them with the excavator. I bet those monster stumps are quite a bit heavier too!
2021 Kubota SVL97-2 (A50123)
2021 Kubota...
2015 John Deere 544K Articulated Wheel Loader (A52377)
2015 John Deere...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A53473)
2014 Doyle Dry...
