YardBikeBob
I built a water tower to tend the wife's garden. Now that it is up, I need to make a decision on how to fill it with water.
The pump must handle 20' of head lift. I've got a couple of questions:
#1 is what to use for a pump. I can haul 250 gallons out to the tower on my tractor. At the start of my over-thinking I was sure a PTO powered pump should do the job. But when looking at what is on the shelf at TSC and Orchelin's, the pumps with good specs are based on 1,000 RPM PTO drives. My tractor offers only 540. To use these pumps I'd have to have the tractor at full RPM to get half the stated performance? Has anyone found a source and good success with a 540 RPM rated pump?
The alternative is a $170 pump offered by our comrades at Harbor Freight: 1 in. 79cc Gasoline Engine Clear Water Pump - 35 GPM. I've got a tiller with a Predator motor so I have some confidence in this brand. Anyone using one?
Other recommendations?
#2 is how to plumb for the water tower. I will bring 2" PVC over head and down to the garden fence. Then I'll run piping along the fence to a couple of hose bibs. If I provide an inlet for the pump at the fence line with proper diameter, will that prove effective? That is, it will be pushing water up through 2" PVC to fill the tank from the bottom.
The alternative, of course, is to run a separate fill pipe that runs up and fills the tank from the top. Can't figure out if the physics of pumping water uphill is different either way.
Appreciate all ideas and guidance.
~Bob
~Bob
