Pushing in 200 T Posts
   / Pushing in 200 T Posts #1
Westonium
Chehalem Mountain area, OR
JD 4310
I've got 200 T posts to push in, and I am planning to use a pounder to start them, and the FEL to push them in - anyone have a better idea, better way?
6' HD Tposts to be fenced with 4' no-climb.
   / Pushing in 200 T Posts #2
You must have different dirt than we do. You wouldn't be pushing no posts in with a loader around here.
   / Pushing in 200 T Posts #3
I've done it with a Bobcat in soft ground.
Temporarily weld a short (~2") piece of pipe to the bottom of your bucket to "catch" the top of the post, so it doesn't slide slideways as you push and bend the post. (or fly back and hit you or the tractor)
If you have a helper, they can hold the post until you lower the bucket, then you won't have to start them with the pounder.
   / Pushing in 200 T Posts #4
Fill the loader wit material, rocks, etc. to use as weight to help drive the post. Worth a try as beating the t-bars with a driver is a shoulder workout.
   / Pushing in 200 T Posts #5
I just finished putting up my fence on one side of my property. I put in 256 T-Posts with a spring loaded driver from TSC. The job wasn't bad at all (except for the heat) if the dirt is all that's there and no rocks. I had about 12 that had to be drilled in because of rock, a pleasent surprise I must say.
I probably moved faster than pushing them in with a loader too,but I can't swear to it. It seemed very fast to me though. The one thing I do know is. It was cheaper and easier than hauling the tractor to site and using diesel fuel. I figure if you can push them in, you can probably drive them in with relative ease.
Just thought I would chime in with this.
Good luck.
Oh yes, I almost forgot. The rain getting the ground wet helped a lot too.
   / Pushing in 200 T Posts #6
Check with a local rental. One down here has an air powered hammer for t-posts. The only problem is that you have to have a gas powered compressor or rent that too.
   / Pushing in 200 T Posts #8
i usually do it the other way, start them with the bucket, then finish with the hand held post pounder...all this is moot if the ground is dry and hard
   / Pushing in 200 T Posts #9
I've used the FEL and a 3ph post driver to set T posts. My experience is;
1. If there are no rocks, you can set the T post with the FEL without any weight in the bucket.
2. If there are rocks, adding weight in the bucket doesn't help, you just increase the odds that the T Post will spring out from under the bucket. Very dangerous.
3. If there are rocks, the 3ph post driver either bends the T Post (dangerous) or it goes in at an angle.
4. To use the FEL, it was best for me to have 2 people. One on the tractor (me) and one to position the bucket above the T post (wife). /forums/images/graemlins/smile.gif Once the bucket was positioned, she got out of the way.
   / Pushing in 200 T Posts #10
I have one of those air cylinder t-post drivers. It works really well and I haven't had any problems with it. I live on the Gulf Coast and most of our soil is heavy clay. When dry it is like concrete. I have a small trailer I pull behind the atv. We load it up with a small gas air compressor and load of t-post. I have areas that are difficult to get a tractor in and use safely. I feel it was money well spent.
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
2025 Safety Basket Forklift Attachment (A51691)
2025 Safety Basket...
2013 W-W TRAILER ENCLOSED TRAILED (A53843)
2013 W-W TRAILER...
Deere 333E (A50123)
Deere 333E (A50123)
