May 7, 2013 / Purge fuel system of air, JD 2155 #1 R rideev New member Joined Jun 19, 2011 Messages 7 Tractor JD 3230 How do I purge the air out of the fuel system on a JD 2155?
May 8, 2013 / Purge fuel system of air, JD 2155 #2 Tx Jim New Member Joined Jan 26, 2007 Messages 10,255 Location Coyote Flats,Tx Tractor JD 4255/Kubota M7040 HDC Open bleeder on fuel filter and pump lever on lift pump. Then open bleeder screw on the side of inj pump and turn engine over until a steady stream of fuel squirts out the bleeder then close bleeder screw.
