Purchasing a used Brush Hog
   / Purchasing a used Brush Hog #1
JamesH
Bronze Member
Paola, KS
JD 4300
I have been looking for a used Brush hog mower to use in maintaining ATV trails through the woods on my 20 acres. I already have a 6' finish mower I use around the house.
What are the key things to look at on a used mower like this?
I would think the main thing to check would be the gearbox. But how or what can be checked on it?
My brother has found an older 5' Case but it is pretty rough. The skirt needs replaced but that is about it. For $150 it may be worth refurbishing. A little work on it does not bother me. It helps to hone the welding skills.
James
   / Purchasing a used Brush Hog #2
Have them hook it up to the tractor and turn it on at idle, then turn it on at 540rpm....just listen to it. If its not making a lot of noise or leaking or shaking violently (it will vibrate/shake slightly), then its probably good to go. If it has a clutch, raise the mower and pull the blades around and you should be able to pull them and have it slip fairly easily.
   / Purchasing a used Brush Hog #3
Look at blade condition, stump jumper (if equipped). Is it all beat up, gouged, etc. Any oil leaking from underneath? Are mounting pins bent, does mower 3ph hookup look twisted, does it have tailwheel, does it appear to have been greased on regular basis? Lots of things to look at, and even if it is rough looking, it will probably still last a long time.
   / Purchasing a used Brush Hog #4
I would sooner buy used underwear. These things take a BEATING. They often won't show it, but a gearbox can be trashed and still act OK whennot wacking trees and rocks. Some things are just much safer to buy new. A hairline crack in the stump jumper or blades or U-joint can be the death of you. My 2 cents. Mike
   / Purchasing a used Brush Hog #5
My goodness. Death? Please.
   / Purchasing a used Brush Hog #6
Definitely check on oil leaks, especially from the bottom of the gear box.
The old Bush Hog I have (and it was given to me so I'm not complaining) was losing oil as fast as I could put it in through the bottom seal.
Everyone I talked to said it would be a bear of a job to change out yourself without the proper tools and probably quite expensive to have done at the dealer.
Because I don't do a lot of bush hogging and the old mower was well....pretty darned old, I just filled the gear box full of grease and we're getting by.
Try no to buy one with that problem. At least check the gearbox and see if it's full of oil or grease.
hud
   / Purchasing a used Brush Hog #7
Any pics? $150.00 sounds ok. With torch and welder, shouldn't be a problem to repair.
   / Purchasing a used Brush Hog #8
How full of oil or grease should the gear box be?
   / Purchasing a used Brush Hog #9
If you are filling with oil, it should be to the bottom of the fill plug on the side of the box. If you are pumping it full of gun grease, pump until you are pushing grease out the bottom of the box. First time it will hold close to a tube of grease. Then periodically pump in another 15 or 20 pumps to maintain contact with the gears.
   / Purchasing a used Brush Hog #10
If you hook it up to a tractor, it is fairly easy to tell if it is worth anything. See if it runs smooth. A brush mower may or may not run as smooth as a finish mower. Some will not run really smooth when new, but you don't want some kind of off side shake. See if the gear box is leaking, both the front seal where the PTO shaft goes on and also the bottom seal by the blades. Take a light to look into the gear box. There have been underhanded dealers and individuals that have put sawdust in gear boxes to make them quite.
It was said above that you should be able to slip the clutch by turning the blades. If you can do that, then the springs are completely backed off. There is no way that you can slip the clutch by turning the blades by hand if everything is setup right.
If it does have a clutch and you buy it, you will need to slip it and adjust before you ever use it. You can come back here and some one will let you know how to do that.
2016 John Deere 310SL (A42021)
2016 John Deere...
2013 KENWORTH T800 (A45046)
2013 KENWORTH T800...
Bobcat 773 Skidloader SALVAGE, OROPS (A43155)
Bobcat 773...
2000 KENWORTH W900 (A45046)
2000 KENWORTH W900...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A42744)
2018 John Deere...
Convey-All BTS-150 Seed Tender  Truck/Trailer Mounted with Honda Engine (A44787)
Convey-All BTS-150...
