Purchasing a Frontier Or Leinbach plow ??
   / Purchasing a Frontier Or Leinbach plow ?? #1
Trap
Northeast KS
Kubota B7610,
OK, I need opinions on which might be a better fit. I am looking at a Leinbach model 19-12"
or a Frontier one bottom 14" plow. This will hook to a Kubota B7610 4WD. The Leinbach is a little smaller and priced around $500, The Frontier is heavier duty and sell for $560. The Leinbach dealer thinks the smaller 19-12 is a better fit but I really don't know why. Perhaps I should call him. My tractor is rated at 25HP. I am just doing my gardens now but if my day job dies perhaps I'll do others in the fall.
Leinbach model 19-12"- weight is 175lbs ($503)
Frontier 1 x 14"- weight is 256lbs ($567)
Leinbach model 81- weight is 225lbs ($553)
The Frontier is locale JD dealer
Leinback is shipped from NC
Any thoughts would be appreciated,....thanks
Maybe a middle buster is a CHEAPER approach......?
   / Purchasing a Frontier Or Leinbach plow ?? #2
I have a leinbach 1 bottom I use behind my BX2230 and love it,I don't remember the model# but it is a 1 bottom 20" wide arm spacing model.Plenty heavy enough in my opinion for plowing for sure.With my Bx I can bury plow in the right ground but on the next pass I can almost roll the Bx over in the fur if not careful so I do not plow more than 8" deep.With you B if you have lug tires I would think it would have no problem. I do a 1/2-2/3 of and acre every year plow still works fine. Good luck, Bill
2015 CATERPILLAR 299D SKID STEER (A51242)
2015 CATERPILLAR...
JLG 2646 ES LIFT (A50322)
JLG 2646 ES LIFT...
2022 BOBCAT T595 SKID STEER (A51242)
2022 BOBCAT T595...
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
CUSTOM TRAILER (A51242)
CUSTOM TRAILER...
2013 Jeep Patriot Sport 4WD SUV (A50324)
2013 Jeep Patriot...
