Buying Advice Purchasing a 3320...help with options please
   / Purchasing a 3320...help with options please #1
North585
Bronze Member
Northern Alberta
X585/2720
Spring is around the corner (today will be the first time above 0/32f in 3 weeks!) so it is time to get ordering a 3320. Reason for the 3320 vs my 2720 is loader capacity. Love the 2720 (60 hours) and is a great tag team with the X585 (will be replacing it with a 748 in the same purchase) however I have not been able to do a number of jobs becuase of the capacity issue.
My plan is to price out the 3320/748 at two local dealers, determine the trade in value with each of them, figure out what I can sell each of the tractors for privately (if needed) and if everything seems fair, buy locally. If selling privately seems okay but the local dealers will not move on their price too much, I will buy in Montana. The USD/CAD configuration price difference is just over $6,000 so driving 8 hours each way to save $6,000 makes sense-especially when the two currencies are at par. Only issue is warranty. By saving $6,000, I can afford to travel there a few times and still be ahead if the warranty issue is large enough to justify the drive.
My plan on the 3320 is to get the following. Please let me know if I've missed anything I should consider, and advice on the hydraulics options. Back hoe yes, potential plow off a qh-hopefully, not to much else i can think of now, but I don't want to get in the same pinch I'm in now where I could have...but I didn't.
Hydro
375 BH (correct model?)
vertical exhaust
300CX
Top n Tilt
P Beyond
3rd function SVC (needed?)
4/5th SVC (needed?)
Electric Diverter (needed?)
Thanks as always for the great advice and help.
   / Purchasing a 3320...help with options please #2
Tires?
Spacers for allowing chains if R-4's?
Forks, iMatch, 4-1 bucket, grappple?
Cab?
Armor?
   / Purchasing a 3320...help with options please #3
I don't understand why warranty would be an issue. Doesn't any John Deere dealer honor the JD warranty, no matter where it was purchased?
As far as options, I remember that the 3320 had a long list of them. I recently looked at one myself. Beautiful machine. The one area where JD falls short and the reason I bought the Kubota, is in the backhoe dept. You should look into a Woods backhoe, more bucket pressure then the JD. If I knew about it last year I would probably be driving a 3320 myself today. Not that I don't love my Kubota. Its just that I have been a die hard John Deere fan my whole life and it wasn't easy making the Kubota switch.
Good luck and don't forget to post some pics :thumbsup:
   / Purchasing a 3320...help with options please #4
Yes, the dealer would...but don't expect the quick service one would get if they were a customer of that dealer.
   / Purchasing a 3320...help with options please #5
Hydro
vertical exhaust
300CX
Top n Tilt
P Beyond
4/5th SVC (needed?)
The 375 BH will need the PB kit. Top n' Tilt requires 2 SCVs which can come from the Electric Diverter kit. What other hydraulic equipment do you have in mind?
   / Purchasing a 3320...help with options please #6
i can assure you , you won't be disapointed with a 375 bh i have pulled out some serious stumps with it , if you don't need a cab go with a 485 it'll pull a woods bh in half .
   / Purchasing a 3320...help with options please #7
Consider the hard lines kit to the FEL Grapple? Power angle front blade?
Will you ever need a mid PTO? Front mount Snow blower? Rotary Broom?
Consider a SS QA instead of the JD There are a lot of FEL mount attachments used & a lot I see have the SS QA - not that many with JD QA
The Automotive Cruise @ $100 - also allows button access to the Load Match, Motion Match function.
Ever plan to pull a trailer on road - get the 7 pin trailer con for $100
Front / Rear Works lights?
If you live in North Alta and ever might want a Cab - get it now - expensive to upgrade later.
This may have changed. Email JD and ask. When I bought my 2008 was told by JD corporate that warranty coverage area is Canada / US.
   / Purchasing a 3320...help with options please #8
Go for the 485 if you can, I have the 447 and wished I had gotten the 448 for $1000 more. My outriggers are moving to the rear on mine, I have about 150 hours on 447 and 900 hr on 3320. You will need weight in the tires (the 447 has problem lifting my rear with weighted tire, 448 would lift it with ease).
   / Purchasing a 3320...help with options please #9
You'll have to stick with the 375BH if you go with a cab model. Open station gets you the more capable 485 hoe.
I guess the "bean counters" at JD corporate believe the added expense of a cab would mean reduced backhoe sales if they offered a hoe model that would add another $1,000 or so to the deal... makes perfect sense!
You didn't elaborate on the "jobs" that you currently do with your 2720. Just loader work? Commercial work? It seems to me that you're spending quite a bit of money for just another 1.5-2hp.
Depending upon what you do with the tractor - that should play an important part in the decision of the model you buy. Or you might find yourself in a similar situation again in a couple of years from now...
AKfish
   / Purchasing a 3320...help with options please #10
My understanding is that it physically will not fit.
Wooden Sleigh (A50774)
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2004 Mercedes Benz E-Class Sedan (A50324)
2004 Mercedes Benz...
Super Star Smithco Bunker Rake (A50322)
Super Star Smithco...
2018 JLG 1932R 19FT Electric Scissor Lift (A50322)
2018 JLG 1932R...
2015 Ford F-750 Box Truck, VIN # 3FRNF7FA8FV745627 (A51572)
2015 Ford F-750...
