Buying Advice Purchase advise
   / Purchase advise #1
ahoude
Yale Michigan
nothing yet
I'm looking to buy a CT in the fall or next spring. Primary uses will be mowing app 5 acres, some tilling, some brush removal, snow removal. This purchase will be about the same time I build a new house. I expect to use it for some of the construction. Local dealer has CK 20, CK25, and CK 30 in stock. Which would be best for my needs. Would I be further ahead with the hydro trans or gears. Father in-law has older kioti 45 hp (? model) and I really like brand.
   / Purchase advise #2
For no particular reason other than 5 acres to mow, I would recommend you get all you can, the CK30. HST or Shuttle shift gear model is up to you. You lose a little PTO HP with the HST, but I like both models and both are easy to use.
I prefer the HST for up-close operation and for any slopes as I feel HST is a little safer in those conditions. Other than that, the synchro shuttle and synchronized gears are fine.
If you're going to do a lot of ground engaging tasks like with disks and plows, then go gear.
John
   / Purchase advise #3
I would say the 30 would be the best for money well spent... although you could get the job done with 20 or 25. I like the HST for mowing applications.
   / Purchase advise
Thats what I was thinking. Probably wont use 30hp all the time but could be helpful when doing some heavy work. The local dealer price difference is only $1000-$1200 more for the 30. What do you guys think about a flail mower vs rear finish mower?
   / Purchase advise #5
</font><font color="blue" class="small">( What do you guys think about a flail mower vs rear finish mower? )</font>
I haven't used a flail, but from my research, I would say unless you have a golf-course-like lawn, use a rear mower. It would appear that a flail mower may be a good bit more maintenance over the rear mower, and the finish mowers do a very good job.
Like I said, this is just my researching, not experience.
John
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2018 XCMG XE210CU CRAWLER EXCAVATOR (A52576)
2018 XCMG XE210CU...
2010 Nissan Sentra Sedan (A51694)
2010 Nissan Sentra...
