Pump rotation?
   / Pump rotation? #1
Mundy
Swartz Creek, Michigan
Satoh Beaver 4X4, Scag Super Z
I am looking into a PTO pump to power my FEL. The one on the tractor has very limited GPM and I want the FEL to move quicker than it does.
My question is:
If I look at the PTO and it is turning clockwise do I buy a CCW turning pump?
The reason for my confusion is if I look at the PTO turning CW then look at the shaft on the pump my reference has changed and the pump would need to turn CCW in relation to the pump housing in order to match the CW direction of my PTO in relation to its housing. Right? Wrong? Maybe?
This seems like it should be real simple but has me quite puzzled.
Regards,
Mundy
   / Pump rotation? #2
Shaft rotation is customarily described from the viewpoint of the end of the shaft that you will attach the coupling, pulley, etc. to. That is, looking down the shaft from the coupling end. So, you are correct. If two shafts are to be direct coupled (ie, a PTO to a pump), one shaft must turn CW and the other must turn CCW since you will be viewing them from eactly opposite (relative) positions.
The Prince pumps are probably the most widely available and all are (I think) CCW.
2005 John Deere L118 Automatic 42in Riding Mower (A51694)
2005 John Deere...
2015 Honda Odyssey VAN (A51694)
2015 Honda Odyssey...
2012 Mack CXU613 Sleeper Truck, VIN # 1M1AW07Y3CM018973 (A51572)
2012 Mack CXU613...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
NEW Wolverine Fixed Mini Excavator Thumb Attachment (A53002)
NEW Wolverine...
2018 Infiniti QX60 SUV (A51694)
2018 Infiniti QX60...
