pump replacement?
   / pump replacement? #1
notme
hello... i have an old case 1816 uniloader the aux hydraulic pump has a bent shaft... still works but has quite a shake to it. need to find a replacement and not having much luck.
its a borg warner pump
# on the case is S125OAK 55R
under that # is 05098
can anyone give me an idea where i might find replacement parts (shaft) or a replacement pump? its belt driven so a replacement would have to be capable of that. can anyone explain what the stamped in #s might say about this pump?
   / pump replacement? #2
Bosch Rexroth purchased Borg Warner gear pumps many many years ago and the info that I have does not exactly match the model code that you have. Attached is old data sheet that you can use for displacement and dimensional reference. The unknown appears to be the shaft.
S = External gear pump
12 = displacement range (size)
50 = 0.58 cubic inch/rev (9.5 cc)
A = SAE ORB side ports
K = SAE A-A 2 bolt mtg flange
5 = unknown shaft
5 = design series
R = clockwise rotation
  • RA10061 S12 S16 S20 S30 gear pump.pdf
   / pump replacement?
5 = unknown shaft
5 = design series
thanks alot... now i can check surplus center or maybe amazon for a cheap replacement.
so the unknown shaft what does that mean? its a 1/2 shaft? which really doesnt matter as i can match a pulley to any shaft?
   / pump replacement? #4
By unknown shaft I meant it didn’t show as an option in the data sheet
Might have some different bearing option for the side load from belt drive
   / pump replacement? #5
A bent shaft will only get worse, so good call trying to replace it. Those Borg Warner pumps are hard to find new now. I’d check with salvage yards or a hydraulic shop that can cross-match the numbers to a modern pump.
   / pump replacement? #6
Did you see the used pump I listed in one of the two other posts on the same subject?
2020 DRAGON ESP...
2017 Ford F-150 Ext. Cab Pickup Truck (A55973)
2017 Ford F-150...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
JCB 2145 (A47477)
JCB 2145 (A47477)
2013 Haulotte 4527A (A57148)
2013 Haulotte...
12' CONTAINER (A52706)
