Pump Number Mystery
   / Pump Number Mystery #1
johandes
International 284
I have a pump off of a 1980's International 284 diesel 4wd tractor. I understand it was manufactured by Komatsu and sold under the IH name. Here is my mystery. The Hydraulic pump is bad causing all the Hydro fluid to spew into the crank case. The pump needs rebuilding or replacing obviously. The numbers on the pump are P2-6DH10-R121. This number is over the numbers 040-8388. I was told that the first numbers are Borg Warner numbers.
IH, Komatsu, Borg Warner are no help at all.
A. Does anyone know where I can get a rebuild kit or get it rebuilt? Nobody seems interested in returning my phone calls. (too small of a job, I guess).
B. EXACTLY what do the numbers mean on the pump. Perhaps I can get a replacement pump armed with that info.
Warmest Regards,
Jim J.
   / Pump Number Mystery #2
Some of these companys had there own number stuck on instead of the pump manufacturers number.
Take picture and post on here, maybe some one will know what it is. Some hydraulic pump rebuild shops if you contact them and send a picture there way, also could give you the numbers you need.
Oldandslow gave me a few outfits to check out when I could not find a "official" Vickers number. I sent a picture and they knew what it was right away. If he does not see this post, send him a message, he will be glad to share his contacts with you.
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2010 International 4300 2,000 Gallon Water Truck (A52377)
2010 International...
JOHN DEERE 7210R LOT IDENTIFIER 256 (A53084)
JOHN DEERE 7210R...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
5" & 6" CHANNEL IRON UP TO 20' LONG (A51247)
5" & 6" CHANNEL...
