Bowhunter
I see crews that seed new lawns using pulverizers quite a bit. What is the advantage of the pulverizer over a tiller? Is it because of the rollers behind the pulverizer? Do these give a firmer seed bed and delete the need to run a cultipacker? From what I've seen, the pulverizer is almost as expensive as the tiller (why that is I don't know), but it seems that a tiller would be much more versatile with many more uses than the pulverizer. If a firmer seed bed is the reason, why not fabricate brackets that allow you to run rollers behind the regular tiller?
Just thinking out loud. /forums/images/graemlins/smile.gif
