3-Point Hitch Pulsing, jumping lift when cold
   / Pulsing, jumping lift when cold #1
o2batsea
Platinum Member
Maryland
Kioti DK45C 2005
I have noticed lately that when I lift the mower deck or the bush hog or whatever is hooked up to the TPH, it kinda bucks and jumps until things warm up. Anyone else experience this? Not sure it is a symptom or a feature. '06 DK45 SEC. Tanks
   / Pulsing, jumping lift when cold #2
I've used my 2004 CK30hst this Winter when it's been 0F'. I start it up, lift the back blade and fel bucket, then let the engine warm up for 10-15 minutes before moving or doing work. The back blade and bucket lift a little slower right after start up but not jerky. Do you have the correct weight hydraulic oil in it and how long since hyd filter change? Mine manual advises hyd and hydro filters every 200 hours with hydraulic fluid every 400 hours. Your tractor has a draft control where mine doesn't. Does it make a difference where it's positioned? Definately a flow problem if it's ok after it's warm.
Deere 333G (A50120)
Deere 333G (A50120)
2014 Toro Workman HD Utility Cart (A51691)
2014 Toro Workman...
2015 Peterbilt 320 Heil Front Loader Garbage Truck (A50323)
2015 Peterbilt 320...
EZ Flow Gravity Wagon (A50774)
EZ Flow Gravity...
2016 Ford Explorer...
