pulling weight???
   / pulling weight??? #1
c23380
NC
2008 ck30
This is a tow part question and discussion. I am interested in pulling trees over, (small ones) and want about 75 to 100 feet of cable or rope. We use to do it with cable back in the early eightys but I was wondering what you guys think about rope. Second part of the question is pulling weight. If the tractor weighs about 3400 lbs what could you expect the static pull of it be in dirt, with 4x4. (30 hp). With its weight being 3400lbs, I would figure it only to pull 2500 to 2800 lbs best case. Is there a math equation to figure this or do you just double the weight and buy cable/rope at that weight range?? Thanks, Mike
   / pulling weight??? #2
I'm sure there is a formula to get a rough estimate but your going to need to know the coefficient of friction of the tires to the surface your on as well as the angle that your conected to the trees
What do you mean by pull over the trees? Are these living trees or dead? How tall?
   / pulling weight??? #3
I have done measured force pulls with AGs on good firm turf. 2wd with a little less than 6000 pounds on the rears. Pull was 7200 pounds at point of wheel spin with locked differential. I imagine your tractor would do around 4000# in the same conditions. More if you hung some weight on it. If youre in dirt I would use chain. Its heavy but trouble free.
larry
   / pulling weight??? #4
Leverage is a big bonus. If you can get your rope higher up in a tree that will certainly help. Using rope that isn't damaged is something you should do. Any tree can do fun things if it is weighted away or at an angle from your pull. Tree's with rot in them can spin. I use ropes often to help guide the tree where I want it to go. With a rope you have some elasticity when you load it with some pull. Where a cable doesn't stretch. The big big thing to worry about is having protection from breaking ropes, cables, tree's, branches, etc. Another thing that I use is pulleys to double or increase the effective pull on the tree. Again Safety is your primary concern. We don't want to be reading about you in the Safety forum.:cool: Another method to get a line higher up in a tree that we use is a slingshot with a string attached. We shoot it into the tree and then haul up the rope with the string..
   / pulling weight??? #5
Small trees? how small. I use a 2700lb tractor tractor to knock over dead trees over 30+ ft tall, but I use a FEL on the back side of the tree a few feet up in a very low gear, it did not take much effort to bring them down. Pulling a dead tree from the front high up would not need much pulling power, but if it had all the roots intact, then it would take much more pulling power. Good 6000lb rope would be OK I would think. Otherwise use a chain saw before anyone got hurt from a tractor incident.
   / pulling weight??? #6
Have you priced rope that will handle that?
Be sure you don't tie it but have hooks in it so you can unfasten it. (my experience here, might be other ropes you can untie).
75 to 100 feet is a lot of rope, are you pulling that tall of tree and think this will be safe, good. But do you really have that long of area to set up to pull in?
If you are trying to pull the stump up also and have the ability to, try running a subsoiler on the back side to cut roots and/or a good soaking of that soil for a couple of days also helps.
I have pulled trees like this with tractor and pick to have them fall where wanted, even against a lean with good results. But also had a tree take a compact pickup and just pull it where it wanted to as it hit my Mom's house. Based upon my limited stump digging from cut trees and digging of trees still on the stump, the top sure helps pop that stump out the group. As someone has already said, leverage is great.
   / pulling weight??? #8
A real handy thing to have when pulling trees is a pully and short chain.
I often wrap a chain around a tree that is in the direction of where I want to fell my tree, feed my pull line and then can pull from any handy direction.
My first 'tree pulling pully' was made from an old wheelbarrow wheel.
I since found an old 'hay loft pully' that works great.
You do want about 8-10" diameter for that to work well!
I, more than a few times, cut and pulled 8-10" maples and birches that were leaning very close to cottages in a dangerous manner should winds have uprouted them.
Always be VERY careful of 'widow makers'!
That is a dead tree that when cut or shaken can drop the top end on your head or tractor.
Even the vibrations of a chain saw can drop those tops!
   / pulling weight???
Thanks for the info. I guess what I am looking for is the What to buy. Rope or cable. Just a best case senerio for instance would be tractor on pavement, with hitch point level with drawbar. What would be the max my tractor would pull? If I get equipment that will handle this, then when I hook to trees higher than my hitch and pull on dirt, then I will never exceed the rated strength of cable or rope. As for the length being 75 to 100' this will make the angle better for better traction. I had planned on digging around the trees and if I could not push them over with the bucket, then I will pull with the long rope and a come-along, or the tractor. Thanks
   / pulling weight??? #10
I agree with Treemonkey, for maximum leverage pulling from high up the tree will most likely tip it. The only problem with this is that forward motion of the tractor lifts the rear end so you lose traction. What I have done is use a snatch block anchored low to keep the rear of the tractor on the ground. To do this you should keep the geometry such that the distance from the snatch block to the base of the tree is greater (much greater is better) than the height up the tree where you are pulling. Also, the lower the snatch block is relative to the tractor the better because pulling then adds weight to the rear wheels.
Steve
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
2013 MAXEY TRAILER MFG UTILITY TRAILER (A53843)
2013 MAXEY TRAILER...
2019 Genie GS-3232 32ft Scissor Lift (A53421)
2019 Genie GS-3232...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
2016Takeuchi TL8 (A47477)
2016Takeuchi TL8...
