Pulling a trailered 3535
   / Pulling a trailered 3535 #1
poolecw
North West Georgia
I have a 2006 chevy Silverado 1500 with the 5.3L engine. Do you guys see any issues with using it to trailer a 3535 that weighs around 4125 lbs?
   / Pulling a trailered 3535 #2
Check the towing capacity of your truck. Should be able to find the information on the sticker inside your door panel. Also remember, the trailer itself does add weight to the configuration. Also, are you setup to add a braking system. When I tow I find its not so much the pulling but the stopping.
   / Pulling a trailered 3535 #3
Check this link. You have to look up your truck. 2WD/4WD, reg. cab, ext cab, crew cab, etc. Everything makes a difference on tow rating. I don't think you'll have a problem guessing your trailer weighs about 2K plus the 4125 = 6125 lb. Trailer should be double axle with brakes on both axles. Minimum rating of 7K. Truck will need a trailer brake controller. Plus the usual tie downs.
https://www.dunesport.com/tow_ratings/tow_ratings_2006.pdf
2013 Ford F-550 4x4 Horton Ambulance (A50323)
2013 Ford F-550...
3pt 7' Tiller (A50121)
2010 Chevrolet Malibu Passenger Car (A51694)
2010 Chevrolet...
2016 Ford F-150 Pickup Truck (A51692)
2016 Ford F-150...
2005 TRANSCRAFT 48 X 102 FLATBED (A52472)
2005 TRANSCRAFT 48...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52748)
Michelin CARGOXBIB...
