timb
Veteran Member
- Joined
- Jun 14, 2002
- Messages
- 1,058
- Location
- Southwest PA
- Tractor
- Deere 4710/reverser, JD 318 (still needs TLC), JD LT160
Showing my ignorence on compacts here but I keep swaying between "medium" and "large" compacts (say JD4310/TC33 vs JD4510/TC40) as I consider different jobs I'll have for it. Can any of the more experience crew out there share a little insight into using a compact for plowing? For example - we have a 2x14 plow (now used with a Ford NAA, 2WD, filled 11x28 ag tires). Would a plow this size be too much for a medium-frame compact, assuming 4WD but unfilled ag tires? (Maybe wheel weights). Not that I'm planning to plow 40 acres every year but being able to compare a newer compact to the old Ford gives me a frame of reference for ground working attachments.
Thanks, Tim
Thanks, Tim
