Pulley drifting
   / Pulley drifting #1
jake98
Veteran Member
Dingmans Ferry PA
53 Cub, 70's JD 410, Kioti 25hst
I replaced the engine on a Kemp chipper with a Horrible Freight horizontal shaft, and am having some difficulty getting the engine pulley to stay put. Any suggestions, or rules of wisdom for that problem? Just installed for the 2nd time with locktite on the setscrews and key, but wondering if I'm missing something basic. Only stayed put for an hour last time. TIA.
   / Pulley drifting #2
Are the pulleys running true with each other ?
   / Pulley drifting
They appear to be, I line up the edges with a straightedge.
   / Pulley drifting #4
You can try this LOCTITE 638
   / Pulley drifting #5
Does the setscrew contact the shaft or the key? If it contacts the key, it won't scar the shaft, but will allow drift. I've seen a lot of pulleys with a short setscrew with a star-like tip that is backed up by another setscrew to keep it from backing out.
   / Pulley drifting
Dan, It has one of each.
   / Pulley drifting
Peter, I locktited it this time, set screws, key, and shaft. Going to let it sit over night before trying it again.
   / Pulley drifting #8
It should work....:)
   / Pulley drifting #9
You could replace the pulley with one that has a browning connector.
With this you wont have any movement.
McMaster Carr, Grainger should have them.
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A51692)
2014 Ford F-450...
2014 FORD F250 XL SUPER DUTY CREW CAB TRUCK (A51406)
2014 FORD F250 XL...
2025 K3325G UNUSED Double Garage Steel Barn (A53117)
2025 K3325G UNUSED...
