Mowing pull type brush cutter on JD 3320
   / pull type brush cutter on JD 3320 #1
491ton
Milton, Iowa
John Deere 3320 cab tractor
I have a 2015 3320 john deere utility tractor with hydro trans and 32hp. Today I was running my 5' new idea pull type mower thru tall fescue at 2200 rpm in mid range, going pretty slow, on hilly terrain, Then I noticed my pto was not turning, I shut off the pto and shut down the tractor. After a bit I started back up, And the pto worked. The question I have, Is this mower to much for the tractor? It is an older model mower, And pretty heavy. My thought, Is mabe the pto clutch was over heating. Thanks.
   / pull type brush cutter on JD 3320 #2
My pto clutch slipped and stuck my post hole auger in the ground, because I had adjusted the clutch wrong. I hope your problem is as simple a fix. At least you won't have to dig an auger out of the ground.:)
2008 Ford F-250 (A50323)
2008 Ford F-250...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
UNUSED AGT MX15RX EXCAVATOR (A51243)
UNUSED AGT MX15RX...
2014 Chevrolet Cruze Sedan (A50324)
2014 Chevrolet...
2013 Isuzu NPR Eco Max Box Truck (A47384)
2013 Isuzu NPR Eco...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
