Pull start
   / Pull start #1
Mary J
M7040suh
Can i pull start my m7040suh?
   / Pull start #2
No idea but I've put our IH 444 behind my backhoe and pull started it. (someone on it of course)
   / Pull start #3
Welcome to TBN
NO!!! hyd pump needs to provide hyd pressure to engage shuttle clutch plates in order for transmission to transfer power to turn engine crankshaft.
   / Pull start #5
As Jim said, it has a wet clutch pack, so no, you can't pull start it. It will basically free wheel once it's out of park.
   / Pull start #6
   / Pull start #7
Std Trans tractors can be pull-started (or coasting & pop the clutch) but not HSTs.
   / Pull start #8
Not with hydraulic clutch packs - need hydraulic pressure to engage clutch.
Toro Workman Utility Cart (A51694)
Toro Workman...
2010 International 4400 National Crane 300C 56FT 8 Ton Crane Truck (A50323)
2010 International...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A50323)
2014 Ford F-450...
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXAT8DH646721 (A51572)
2013 Dodge Charger...
Ford 1710 Tractor (AS IS) (A50774)
Ford 1710 Tractor...
