PTO
   / PTO #1
timnalette
I have a mahindra 2810 with rear and mid deck PTO which I have not used since I had the tractor and decided to check its operation and noticed the shaft didn't rotate when engaged (there is a lever to engage, a button to push, and a switch to engage) - I can hear the engine surge a little as it appears to be pumping fluid but the rear shaft doesn't rotate, however the mid deck PTO does. Are the two operated by the same solinoid/valve assembly so that I can assume that is working properly? Any suggestions/help would be greatly appreciated - the tractor is 2 years old - thanks /forums/images/graemlins/confused.gif
   / PTO
2021 JCB 1CXT Skidloader/Backhoe (RIDE AND DRIVE) (LIKE NEW) (A50774)
2021 JCB 1CXT...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
2020 Cadillac Escalade 4x4 SUV (A50324)
2020 Cadillac...
2007 PETERBILT PB335 LUBE TRUCK (A51243)
2007 PETERBILT...
2020 Kenworth T880 Tandem Axle Day Cab Road Tractor (A47384)
2020 Kenworth T880...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2019 CATERPILLAR...
